F4i 636 Cluster Project Is A Go
I'm sure some 1337 uber hacker and electronics nerd could figure it out, but yeah, they're designed to keep people honest about their mileage.
after using my highly advanced matching skills i have come up with the following...
636/F4I
Ignition/Ignition
FI light/FI light
Tach. Pulse/ Tach.
Ground/ (-)
Battery/Battery
Right Turn/ Right Turn
High Beam/ High Beam
Neutral/Neutral
Oil Pres/Oil Pres
Water/Water
Fuel Res/Res. Sensor
Okay now extras I need to know how to pair..,.
F4I Extras
Side Stand
Sensor (-)
Illumination (+)
Speedometer
636
Stop Watch
Lap Timer
Speed Supply
Speed Pulse
Okay guys help me out here
636/F4I
Ignition/Ignition
FI light/FI light
Tach. Pulse/ Tach.
Ground/ (-)
Battery/Battery
Neutral/Neutral
Oil Pres/Oil Pres
Water/Water
F4I Extras
Side Stand
Sensor (-)
Illumination (+)
Speedometer
636
Stop Watch
Lap Timer
Speed Supply
Speed Pulse
Do you know anyone with a 636? It'd help if you could put a DMM on those extra 636 wires and see what kind of voltage they're getting.
I'm guessing speed pulse/speedometer
Lap timer and stopwatch might just need (+) or (-) 12V while the engine is running.
Side stand probably isn't going to be used.
No solid idea on sensor and illumination. They might just need (-) and (+) 12V with ignition in run position.
yeah i was thinking the same thing kowen said. Speed pulse to speedo, illumination goes to the ignition wire on the f4i so just do that or give it another + 12v source. Youll prob have to do without the side stand. Then just give the rest a + 12v source. Whats the speed supply wire do?
