F4I 2001 Fuel Pump Not Priming
Old 06-29-2015, 04:10 PM
bowflexmaverick's Avatar
Default F4I 2001 Fuel Pump Not Priming
Hey Guys! So just picked up a bike that I'm taking in for a project bike. The guy says that the fuel pump doesn't work, but I just want to make sure. I turn the key, everything comes on, except when I turn off the kill switch, I don't get the prime of the pump. Nor do I hear a click, ( possibly a bad relay). The BAS is hooked up, kickstand up, except on the front headlight harness, the flasher relay is missing, and I'm not sure what to do with the frayed out wires? (Also Maybe the problem because of an incomplete ground)? I'm really bad at electrics troubleshooting, and any help would be greatly appreciated
Old 06-29-2015, 05:35 PM
And how could I close off the 3 open wires that I have that are suppsoed to be going to the turn relay at the front? Kinda sketchy having those just dangling around open with no plug
Old 07-03-2015, 11:57 AM
reaper101's Avatar
By pass the fuel relay if it works than that's ur problem if it doesn't bypass the bas sensor and see if that's bad, if nothing bypass both no work? Than its most likely ur fuel pump
Old 07-06-2015, 03:43 PM
How do you bypass the fuel relay?
Old 07-07-2015, 10:00 AM
reaper101's Avatar
With a wire just plug it in in one side, if ur unsure I'll post a pic later I'm at work atm
Old 07-08-2015, 10:05 AM
That'd be awesome! I just bought a multimeter and am trying to learn how to diagnose
Old 07-08-2015, 04:41 PM
Ok so for some reason I took off the power commander that was on there before and tried clicking the kill switch, and it finally did something! Not sure why that would make a difference. But it flashed the FI red light on when I clicked it and I heard the click of the relay in the back when I did! Some progress....
Old 07-08-2015, 04:42 PM
Anyone know why the power commander would make it so it wouldn't allow the Relay to turn on?
Old 07-09-2015, 06:41 AM
reaper101's Avatar
Completely forgot to take the pic I'll do it today tho, mine is bypassed by previous owner who made it into stunt bike and said the relay would keep him from doing long wheelies but about the power commander I don't know never had one, maybe it's not programmed correctly?
Old 07-09-2015, 08:26 AM
It's all good So just thinking ahead, if the fuel pump is bad, could I just buy one of these sets on ebay to repair it?
Lifetime Warranty New Intank Fuel Pump for 2001 2006 Honda CBR600F4I CBR600 | eBay
Quick Reply: F4I 2001 Fuel Pump Not Priming
