f4i to 03 rr tail swap
Old 11-09-2009, 08:14 PM
jman21lax's Avatar
Default f4i to 03 rr tail swap
I was wondering, as far as the rr tail plastic goes, will i need to switch out the elctrical setting box? and obviously ill need to swap the actual seats?
Old 11-10-2009, 12:47 PM
skoobydoobie's Avatar
It's not a simple bolt on swap. You will need to do some fab work to the sub frame and tail section to make it fit. If you're tryin to get rid of the "banana" seat, then it's easiest to use the '01-'03 F4i set up. It's a direct bolt on, you'll need the sub frame, fairing, under tail, tail light, and seats.
Fareal321
04-14-2012 06:15 AM
Hootie233
08-25-2010 03:08 PM
scottiekarate17
10-22-2009 07:58 AM
nxfedlt1
02-17-2006 09:51 PM
Quick Reply: f4i to 03 rr tail swap
