F4 engine into an f4i. Will it work?
The heads are different as is the timing. I can tell you this for sure as I had both bikes side by side and worked on them the same time. got 2 f4 motors in the shop and vangill's old f4i motor to go with my f4i. The f4i has a cam pulse sensor needed for the FI that the F4 doesnt have. Cams are different. I dont know if the cranks are different or not. the timing difference may be in the cams and if thats the case then the f4i head would bolt on the f4 and it would work fine. The gearing in the tranny is also slightly different which you can verify by the 2 different service manuals. its only a slight difference though and wouldnt be that noticible.
