F1 light on cluster
Old Oct 24, 2010 | 01:23 PM
mark1785's Avatar
Default F1 light on cluster
I just replaced the motor in my 02 f4i 600 and the red f1 light is on the cluster. Does anyone know what that means?
Old Oct 25, 2010 | 07:05 PM
R Dub's Avatar
October 2011 ROTM
There is a way to pull the code. Get a copy of the manual and it will tell you how. Once you do it the FI light will flash a certain amount of times then the manual will tell you what that means and that should point you in the right direction.
Old Oct 25, 2010 | 07:20 PM
mark1785's Avatar
Ok thanks. I have a connector that is not connected and I think it is the map sensor but I can't find it anywhere. I'm going to pull the tank again and try and look again for it.
Old Nov 16, 2010 | 07:51 AM
mr_pea's Avatar
im currently fondeling with the map sensor on my bike...
it is located on the LHS of the bike fixed to the bottom of the airbox. to remove it you have to remove the air box... (yea i know stupid design..)
be sure to check your vac lines to the sensor as well as mine was cloged with **** and caused to make the bike run rich.
hope that helps
Beers Joel
Old Nov 17, 2010 | 08:10 PM
mark1785's Avatar
yea i found the sensor and pluged it back it and the light went off but after driving it for a while it came back on and the speedo was working and then it stoped showing the speed so i dont know what is wrong not
cam_pty
Oct 17, 2013 09:01 AM
Mr.Sales
Apr 13, 2012 03:10 PM
Mad22
Mar 14, 2011 03:43 AM
Dice
Jul 6, 2006 12:45 PM
bwp777
Aug 23, 2005 05:38 PM
