engine compression
Old Jul 26, 2009 | 06:07 PM
atxf4i's Avatar
Default engine compression
About 2 months ago I take my bike to the shop because it wont start. Ran fine one day not the next. They thought it was not getting fuel but found out it lost compression so it wouldn't crank. They said they oiled and lubed the motor i guess the heads. Its ran fine put another 3K and now its doing the same thing. Any ideas, ever heard of a F4i losing compression?
Old Jul 26, 2009 | 10:57 PM
mikey49's Avatar
Sounds like you might have a sticky valve. How many miles on your bike? Do you loose compression on all cylinders or just one? Your battery may be low too from cranking. Loss of compression won't normally stop the cranking of the engine.
mikey
Old Jul 27, 2009 | 01:08 PM
atxf4i's Avatar
the bike has 25K, I'm not sure about which or how many valves didn't have compression. Its headed back to the shop tomorrow
Old Jul 27, 2009 | 04:55 PM
mike and ikes's Avatar
You might try taking it to a different shop. One that can fix it for good this time!
Old Jul 27, 2009 | 08:49 PM
bwayers's Avatar
if it's losing compression on all cylinders then it might be jumping time
the only way i could see this happening would be if you have a manual cam chain tensioner that has backed out over time
if it's on one cylinder there are lots of things that could cause it, bad rings, worn or scorched cylinder, loose spark plug, bad head gasket, sticking valve, bad valve clearance
CJardine
May 5, 2013 01:24 PM
anonu
Apr 14, 2012 08:20 PM
tmihaylov
Dec 23, 2007 01:42 PM
corteztk1982
Sep 4, 2007 12:42 AM
Triangle
Jan 17, 2007 03:15 PM
