Engine Can't start when engine is warm
Old Dec 26, 2020 | 12:24 PM
Ram Zandany's Avatar
Default Can't start when engine is warm
Hi guys,
i have an engine starting problem on my 2006 f4i.
When the engine gets warm above 75-77 c° (170 F°) the sound becoming alittle rough.
If i cut the engine off and try to start it again it won't start.
The starter works very slow like the battery is weak (battery replaced and still the problem remains).
After the engine gets cold it starts no problem.
Anyone had this problem?
thank you for your answers,
Ram.
Old Dec 27, 2020 | 08:33 AM
wes 17's Avatar
I understand you replaced you battery but have you checked your charging system ? You need to use a meter to confirm this. It’s not difficult so if you haven’t got one either borrow one or buy a cheap basic one. If your unsure how to do this, a forum member will be here to talk you through it.
A simple oil and filter change might quieten your bike or she might need further servicing if she sounds no better.
Best of luck mate.
Old Dec 28, 2020 | 02:24 PM
boredandstroked's Avatar
If you open the throttle some when its hot, does it fire up?
manxtim
Dec 30, 2012 06:01 PM
ddvs
Feb 12, 2008 02:51 AM
Aracanth
Sep 12, 2006 09:49 AM
DWAYNEVAQ132
Aug 21, 2006 10:52 PM
