ECU needed for CBR 600 F4I
Old Apr 16, 2008 | 04:31 PM
gunjanks's Avatar
Default ECU needed for CBR 600 F4I
Hi people,
It seems that the ECU & Ignition pulse generator of my CBR 600 F4I might be screwed up. Any idea where I can procure them from urgently. Any place in India where one might get hold of them? What are my other international options??
Regards.
Old Apr 16, 2008 | 04:47 PM
ampfp's Avatar
Default RE: ECU needed for CBR 600 F4I
Before you get it, if you post up symptoms of your problem people here might be able to help you locate the problem.
Old Apr 16, 2008 | 05:18 PM
gunjanks's Avatar
The engine was initially running perfectly fine, except for one time when the spark plugs got fouled up and had to be replaced. The engine was then transported for some distance via truck, after which it fired only once, and then stopped sparking at all. I examined the cam pulse and ignition pulse generators, and found that the ignition pulse generator was giving very low voltage pulses as seen on a CRO (~0.1V peak types) while the cam pulse generator gave respectable values (~1.5V peak types). I then fiddled with the wiring to check for loss of continuity, and while attempting to crank up the engine, one of the wires from the ignition harness got shorted with the engine cylinder head, as a result of which the corresponding spark plug adaptor blew up. I then replaced the adaptor, but found that the fuel pump was no longer running whenever the kill switch was activated. Also the dashboard stopped flashing the 'key' and 'FI' lamps after this. I suspect the ECU might have been damaged during this incident, but I am still not very clear why I had no spark initially. I suspect my ignition pulse generator not functioning to be the reason for getting no spark initially.
Old Apr 16, 2008 | 06:15 PM
StreetPower's Avatar
still, the main 20A fuse should blow before the ecu would be fried. i had no spark some days ago and it was because the dumbass which assembled my bike didn't tighten the bolts on the ignition pulse generator(crankshaft position sensor) and it just untightened and fell off. and yes, that's because of the sensor.
Fubadu_the_Mighty
F3 Wanted
Jun 22, 2010 11:38 AM
jonnym61
Mar 4, 2010 01:36 PM
MattG
Aug 29, 2008 05:40 PM
barryem
May 8, 2007 01:55 AM
stilin
Sep 20, 2005 10:19 PM
