Drive Chain Issues
Old Sep 25, 2009 | 01:08 PM
dave ls1's Avatar
Originally Posted by Da11en47
Is that "replace chain" indicator really accurate? I have 14,000 miles on mine and it is not even near the replace area?
I had 12K on my chain and sprockets. It was also far from the 'replace chain' indicator.
Old Sep 25, 2009 | 01:11 PM
PlayfulGod's Avatar
was the chain wore out or the sprockets tho?
Old Sep 25, 2009 | 01:17 PM
chetman7's Avatar
my chain slack hasn't changed for over 1200 miles...is that weird??
and I dont' drive like a grandma either
Old Sep 25, 2009 | 01:21 PM
PlayfulGod's Avatar
mines been like that too. Think I may have adjusted it twice since I installed it last year, and once was a tire replacement lol
Old Sep 25, 2009 | 06:12 PM
dave ls1's Avatar
Neither, I just wanted to replace everything with higher-quality parts.
Old Sep 26, 2009 | 04:07 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
I had a similar issue a while back. What happened was axle grease had gotten on the threads while reinstalling, so even though it was torqued, the axle was moving. Degreasing the axle bolt & nut fixed it.
Axle torque spec is 69 lbs. ~ easy to remember
Old Sep 29, 2009 | 01:38 PM
skoobydoobie's Avatar
Originally Posted by 2H company
Ohhh that's a good point. What's the torque for those axle adjusters?
You DON'T torque the adjusters at all, you torque the axle nut to 69 ft. lbs. And quite goin to the damn shop to fix the simplest of things.
Old Sep 29, 2009 | 02:23 PM
2H company's Avatar
Yeah, that was the lack of practice knowledge.
I see how the adjusters work now, everything is super simple. Just get the axle nut torqued to 69lbs and good to go.
Old Sep 29, 2009 | 03:54 PM
boredandstroked's Avatar
The swingarm wear indicator only tells you when your chain has stretched to the point of replacment. It has nothing to do with sprockets or wear on the chain like tight spots. Chains tend to loosen up really quick when they are going bad. My stock set went 16,000 miles with no wear on the sprockets at all and not even 1/4 of the way from "new" on the indicator then I went past "replace" within 2 weeks and 500 miles. It also welded one link together and had 3 other very tight spots by the end.
ranchome
Mar 16, 2011 07:40 PM
lhall6649
F3 Wanted
Oct 12, 2010 07:24 PM
davefolds3
Apr 21, 2007 01:45 AM
davefolds3
Apr 18, 2007 05:12 PM
spaceman63
Sep 20, 2005 12:34 AM
