Dirt on valves
Ok so I was in the process of pulling my throttle bodies off and upon doing so i got some dirt down ontop a couple of the valves. What would be a good way to get the dirt out so I dont damage the engine
If you are really paranoid about it, get a shop vac or something, and tape some 1/4" vinyl to the end of the vacuum. suck out the bits from the valve seats. If your lucky, all the intake valves will be closed, or nearly closed.
Shouldn't be a big deal though if you leave it.
On a side note, always stuff a rag in your ports when you have the carbs off (I know that doesn't apply here, but just a word to the wise!)
