Definitive answer
Well, I get to answer my own question! I was looking in the shop manual under the Valve/Cylinder section (8) and not in the Valve Clearance Check section (3).
Just fyi for anyone else interested, you don't remove the CCTL, just retract it, and then check clearances...
After taking measurements, all the valves are at the very bottom of spec (towards tight) or just out of spec (again, too tight). Since I've got it open, do you think I should just go ahead and re-shim all of them or only do the ones currently full out of spec?
