Definitive answer
Old Dec 30, 2019 | 06:45 PM
Doc Samson's Avatar
Default Definitive answer
I'm in the midst of my valve clearance and just want to confirm that the CCTL stays on when taking measurements, right?
Old Jan 2, 2020 | 03:52 PM
Doc Samson's Avatar
Well, I get to answer my own question! I was looking in the shop manual under the Valve/Cylinder section (8) and not in the Valve Clearance Check section (3).
Just fyi for anyone else interested, you don't remove the CCTL, just retract it, and then check clearances...
Old Jan 4, 2020 | 03:30 PM
boredandstroked's Avatar
The cam chain doesn't matter when setting clearances, but it can't be putting any force on the cam gears either.
Old Jan 5, 2020 | 07:20 PM
Doc Samson's Avatar
Got it sorted, thanks!
After taking measurements, all the valves are at the very bottom of spec (towards tight) or just out of spec (again, too tight). Since I've got it open, do you think I should just go ahead and re-shim all of them or only do the ones currently full out of spec?
Old Jan 6, 2020 | 02:01 PM
I would do all of them, because they will only keep getting tighter. Set them to the loose end of spec.
Old Jan 6, 2020 | 03:44 PM
Doc Samson's Avatar
Okay, thanks!
GILL
Feb 17, 2008 08:02 AM
SwashBuckler
May 23, 2007 03:30 AM
suream
Jul 13, 2006 03:47 AM
