Coolant for F4i ??
I had to fill up the radiator with coolant tonight after finally getting everything put back together. Without thinking, I used generalpre-mixed Antifreeze for a car or truck. Then decided to look in the manual and it says to use Honda Antifreeze or something similar. Does it really matter? Is what I used ok or should i drain it and put in the Honda stuff?? Thanks...
ORIGINAL: 06CBRF4i
it also matters on the silicates - some additives are hard on the pump seals
Have a look and see what the jug says and read the honda manual for what it says...
will it hurt the bike? I don't know - I doubt it - but I use the right stuff... non-honda but has the right specs.
