connected power commander fuel pump does not turn on
Old Apr 1, 2008 | 09:16 PM
cjr5137's Avatar
Default connected power commander fuel pump does not turn on
i just put my power commander in and loaded the map but my fuel pump will not turn on any suggestions????????//
Old Apr 1, 2008 | 09:45 PM
white99gt's Avatar
Default RE: connected power commander fuel pump does not turn on
you most likely hooked up the wrong connector under the tank..The one that looks EASY to get to is NOT the correct connector.
Old Apr 1, 2008 | 10:10 PM
Fort Collins's Avatar
ya your probably pulled your fuel pump wires. I did the same thing no worries the one your going to be looking for is under all the crap and a pain to get to mine was. but just look around it looks just like the one you pulled just under all of it. I would tell you where but they put it in different spots for different years sorry. good luck!
Old Apr 1, 2008 | 11:50 PM
cjr5137's Avatar
thanks guys i figured it out and it started right up no problem then i downloaded a map and i should be good to go. by the way anyone have a custom map rs3 s/o and stock air filter
FungryMan
Aug 12, 2016 04:45 PM
specializedfuji
May 11, 2009 10:04 PM
F4iT
Oct 5, 2007 10:31 AM
lifties
Feb 14, 2007 12:43 AM
michfan1
Sep 6, 2005 07:00 PM
