Complete Oil Filter List
Old Jan 30, 2013 | 02:08 PM
Nekronaut's Avatar
Default Complete Oil Filter List
Just a little comprehensive list I use to use thanks to the good people at HondaShadow.net
Not only does it have a variety of listed motorcycle and workable car filters for most every model of the CBRs up until '03 but, it has a large list of other manufacturers and models for varying years - for what looks like up until 2007.
Motorcycle Oil Filter Cross Reference
F4i List
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
Wal-Mart SuperTech ST6607
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Automobile Filters,
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Automobile Filters,
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Millard ML-3593
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
A recommended sticky.
Old Jan 30, 2013 | 03:36 PM
omg209's Avatar
whats makes the recommended have superior filtering? and is filtering the only thing we are comparing?
Old Jan 30, 2013 | 09:15 PM
Nekronaut's Avatar
Honestly I'm not entirely sure what makes the recommended ones "superior" to the first in the list, I would assume they are just more efficient in their job; filtering. I would also assume the primary comparison is indeed filtering capabilities.
Turns out the F4i uses the same filters as my previous bike and, I've used a couple filters from this list on that bike and everything was golden.
Old Jan 30, 2013 | 11:19 PM
boredandstroked's Avatar
Longer filters in effect increase the oil capacity of the bike as well as forcing the oil to travel threw more filter media before going to the engine.
Old Feb 9, 2013 | 07:25 AM
That's a nice list of filters. The site you linked to has great information on filters as well as oil.
Longer filters in effect increase the oil capacity of the bike...
This is a good thing. More oil means it has more capacity to absorb heat to cool the engine more efficiently as well as last longer before becoming dirty.
...as well as forcing the oil to travel threw more filter media before going to the engine
I'm not so sure I agree with your statement here. The way that oil filters are made (you can look here at ones opened up), the oil from the bike enters the center portion of the filter and must pass through the filter membrane somewhere. A longer filter provides a greater surface area for the oil to pass through. This too is good. It will take a longer time for the filter to become clogged. The filter material is not set up sequentially, meaning that the oil doesn't pass through all of the filter material, but only from one side of it to the other like a membrane.
Old Feb 9, 2013 | 08:48 AM
RudyGT's Avatar
so bigger filter just means longer time without change as if the normal route gets clogged up it finds the next point of least resistance?
and speaking of good filters how does the OEM honda filter rank? i just picked one up, btw i hear the HRC filter is the same size as well.
Old Feb 9, 2013 | 09:20 AM
74demon's Avatar
The "longer" filter is only about a 1/2 inch longer. There is not much gain in filter media to make it worth putting the end of the filter that much closer to the hot header. I usually change the oil so frequently, that restriction shouldn't be an issue while extra heat in the oil could be. IMO....
The reality is that neither filter makes any real difference and either will be fine, but use the one that makes you feel better.
Old Feb 20, 2013 | 01:18 AM
mnguyen84's Avatar
I use the Fram 6607. In the past, I would get the supertec one, but walmart no longer carries it.
Old Feb 20, 2013 | 06:53 AM
CJardine's Avatar
Track junkie & modaholic
I have only heard great things about the Honda Oil Filter and that it is made well. I felt safe with it on my bike but it was a pain in the *** to get off but Im not currently using it. Never heard of an HRC oil filter so I cant provide feedback on that.
Old Feb 20, 2013 | 01:29 PM
Nekronaut's Avatar
Yeah Wal-Mart stopped carrying and producing a number of quality oil filters apparently , or so I heard via the Shadow guys.
I just put on a Fram PH7317 the other week as I use to use with my Shadow Spirit, seems to do the job.
CJardine: Had an OEM filter on mine as well when I did an oil change the other week..also difficult to get off. People tend to over tighten filters on their vehicles.
Dragondima
Feb 28, 2011 03:17 PM
jharbinson
Aug 15, 2009 09:58 AM
usndocjaysin
Sep 21, 2007 10:18 AM
aaron1085
May 10, 2007 12:18 PM
steve00ses
Oct 14, 2006 07:10 PM
