Competion Werkes fender eliminator kit
If you're going to invest the money in purchasing a FE kit, I highly recommend the CompetitionWerkes FE Kit.
I have the CompetitionWerkes FE on my split-seat. Its very nice high quality & installs exactly as its supposed to w/ no surprises. Its a very solid FE that includes the license-plate & rear signal brackets. The license-plate bracket is easily removable for trackdays. Also, the kit relocates the factory license-plate light for reuse w/ the kit.
The signal brackets that came w/ my kit were for the factory OEM signals. I called CW & ordered the smaller brackets for small LED signals (although you could easily make your own). Their customer service was professional & the new brackets were shipped promptly & work prefectly.
The cutting of the battery tray isn't rocket-science. Simply cut back to where the directions show & you're ready to install the FE.
Hope this helps.
Hope this helps.
Since pictures can be worth a thousand words , here's a few pics of the install...
Fender cut back...
FE w/ brackets, tail light, & lock installed...
FE w/ brackets, tail light, & lock installed cont'd...
Wiring done, factory license-plate light installed...
Job done...
Job done cont'd...
Fender cut back...
Job done...
Job done cont'd...
cbr, comp, eliminator, f4i, fender, forums, honda, install, installing, kit, kits, werkes, wwwcompetionwerkesfender
