Clutch hook up
Old Aug 6, 2010 | 04:33 PM
drunkinmist's Avatar
Sprocket Hauler and Savior
Default Clutch hook up
Hey I just installed my clutch but i am having an issue with trying to get the Pin and rod to meet and get resistance.
Is the lifter pin supposed to have free play?
Is there a way to feel it out? Anything i am trying to get it to work before work tomorrow!
Old Aug 8, 2010 | 07:51 PM
Hey guys has anyone done there own clutch replacement i see that peps have replaced them but did you all have the shop do it?
I can't seem to get any resistance on the clutch lever on the right case housing. I have placed it back on with the pin in place and don't get any resistance.
Is the pin supposed to have about 1" 1 1/2" of free play when you put the clutch plate back on? Is the clutch bearing supposed to be flush on the plate?
Old Aug 9, 2010 | 08:56 AM
joeroberts's Avatar
What do you meen by free play?
I just did My clutch yesterday was Very easy.
Pulled off cover (was the hardest part getting it to separate from motor.)
removed the presher springs Pulled off the primary Plate and pulled each clutch and steal out one at a time.
reversed this with new plates and steals.
put the primary plate back on put new springs on.
when you put the cover pack on make sure the pull rod is all the way down in the cover and the large opening is toward the pull out PIN.
put cover back on(Dont run one bolt all the way down tight)
I took a rubber mallet and taped to cover back onto the motor at this point you should be able to turn the clutch rode towards the cable and it should stop about 1.5 inchs from it Give or take I didn't measure.
put cable back on and adjusted the clutch.
Old Aug 9, 2010 | 09:09 AM
Mister Skizzels's Avatar
I have replaced my own clutch on my 2002 Honda CBR F4i..it was easy. Only thing that I screwed up was putting the stupid crank sensor in backwards and the bike wouldn't start afterwards. :P
On youtube there is a video of a clutch change in a 2002 Honda CBR F4i...take a look at it.
Are you talking about the pin that sits in the middle of the clutch packs that will disengage the steel plates and clutches? When I was done with everything, you could push the pin in towards the motor, and then pull it back out until it stopped hitting the pressure plate.
Did you replace the springs too? At 10,600 miles the springs on my clutch were worn and shorter than my new OEM springs.
If you are talking about getting the rod that connects to your clutch cable and the pin to meet correctly, you need to flip the arm to the left so that the pin and rod will mesh correctly.
Again, take a look at the video on youtube..its super easy.
Old Aug 9, 2010 | 12:01 PM
Sick97SS's Avatar
I'll be doing mine as soon as i get some extra cash and will be using that ebay video as well.
When they reinstall the clutch cover they turn the pin on top of the cover to the left to allow the rod to seat properly,
jaynd
Sep 29, 2008 10:28 AM
sublime420ec
Jan 29, 2008 10:58 PM
Det99cbrf4
Sep 24, 2007 08:03 AM
city worker
West
30
Aug 25, 2007 07:39 PM
Sparkie
Nov 2, 2006 03:42 AM
