finally! got my clutch cable hook
RE: finally! got my clutch cable hook
Not really... it just kinda slides back against the lower fairing stay. Never kinks up or anything. Try turning the bars full LEFT and in the opening on the right side fairing, pull the clutch cable tight where it goes through that ziptie that holds it to the frame. That'll take any unecessary slack out of it so there's less to bunch up when you turn right
You guys have gauges! Pff...I was so annoyed with that cable issue that I took out my gauge cluster all together. No more issue for me.
Heeh,my F4i is astreetfighter now with no cluster to worry about. Does that guide that your using make your cable seem tight when turinig against either side stops (pinch the line when turned to the max)?
ORIGINAL: 02cbrf4i4u
I ghetto rigged one and now my clutch is a little tighter than normal..I can see why this would happen....but did any one else experience this or am I the only one?
