Clutch engages really late
Old May 29, 2010 | 09:30 PM
ddaren's Avatar
Exclamation Clutch engages really late
Hey guys, I let my friend install HIDs on my bike. When I came over to pick it up and rode it, I noticed that the clutch engages really late. When at a stop and in first gear with the clutch pulled it, my bike USED TO start to creep forward when I released my clutch about 3/4 of the way. now... I pretty much have to release it almost all the way before it starts to creep even a little. My friend doesn't know what happened.
Anything I can do? Do I have to adjust the clutch cable or something? Never done it before...
2001 F4i...
Old May 29, 2010 | 09:40 PM
DBEAU's Avatar
There are adjustments on the lever and down by the clutch cover. Start playing around with the lever adjustment.
Old May 29, 2010 | 11:06 PM
ddaren's Avatar
The one by the lever... is it just a **** looking thing right next to the handle? I've never done anything like this to the bike before...
Old May 29, 2010 | 11:50 PM
Zero1080's Avatar
You can't miss the one on the clutch cover, it's the only thing that moves when you pull the clutch. Also, there's a plastic black piece on the lever that adjusts it.
That's probably the only issue, but I do know that mine enages at about the halfway point. I never need to pull my clutch more than halfway in.
Old May 30, 2010 | 11:21 AM
Combat_F4i's Avatar
Loosen the lock nut that holds the cable, its the round flat shaped washer looking thing. That will allow you to adjust the clutch cable nut. Your gonna wanna turn it clock wise, or outwards, towards the middle of the bike. This should tension up your lever a bit and increase how fast the lever bites. Then check how it works, and tightn down the lock ring again.
Check your manual, theres a how to.
Gnarly 928
Apr 23, 2013 11:40 PM
hardyaf
May 14, 2011 12:27 PM
motorad service
Jan 21, 2010 02:48 PM
woo545
Oct 10, 2008 01:43 PM
