Changing the windscreen
Old Mar 29, 2010 | 07:49 PM
loki5068's Avatar
Default Changing the windscreen
hey guys this is probably a noob question but im thinking about changing the stock windscreen on an 06 f4i and i was wondering if i need to take the front off to do it or can i just leave it on?
thanks guys
Old Mar 29, 2010 | 07:52 PM
RunwayOneSix's Avatar
You leave the front fairing on. Windscreen removal is actually quite easy. Just remove the screws securing the windscreen.
Old Mar 29, 2010 | 07:58 PM
loki5068's Avatar
sweet thanks for the quick response
Old Mar 29, 2010 | 08:04 PM
chetman7's Avatar
I dunno how other windscreen are but I had to transfer those rubber nubbins over to my new windscreen..that was a complete PITA. worst part about it..I late realized the screen had a defect and I had to transfer them all back
Old Mar 29, 2010 | 08:12 PM
teko1020's Avatar
Replacement parts very rarely, if ever, are sold with hardware. That said, I didn't have much of a problem with the "rubber nubbins." I just used a screw driver to put them back in.
Old Mar 29, 2010 | 11:10 PM
morepsolrider's Avatar
has anybody tried making a windscreen from flat lexan?
Old Mar 29, 2010 | 11:28 PM
Captlombardi's Avatar
pretty sure flat wouldn't work since it has a curved shape to it.
6 allen head screws will let you take out the windscreen. new one goes back in the same way.
Old Mar 30, 2010 | 12:55 AM
i was just looking at min the other day and it looked like if u bent a flat peice and cut it right it would work...i dunno??
Old Mar 30, 2010 | 08:31 AM
Sick97SS's Avatar
rubber nubbins?
Mine came with the gold "volcano" style allen screws to mount the windscreen, with normal bolt and washer underneath . It's a pain in the a$$ to get to the bolts all the way behind the gauge cluster without them dropping down into the front of the bike. These rubber nubbins sounds interesting.
I just replaced mine about 2 days ago...my last ebay screen was sun-bleached.
Old Mar 30, 2010 | 10:36 AM
itgbudeev's Avatar
Its technically simple but physically a PITA. And yes the rubber nubbins are the wosrt part. But I discovered that the needle nose channel locks I have make the last 2 behing the gauge cluster infinitely easier.
