Chain/Sprockets Question
Smaller, thinner chain means that it will stretch quicker and need replacement sooner. However, it is lighter and has less rotating mass and drag.
Unless you are going to the track an looking to shave off .5 sec or want to do a race type mod, stick with the 525 setup for street riding.
Make sure you get steel sprockets. The aluminum ones are lighter an racier, but wear sooner
If you have seen me post before, you know I'm new with bikes. I recently bought a 2004 CBR600F4i and I need to replace the chain and sprockets. I just have a few questions before purchasing one. I want a yellow chain and the only one I could find was on its own and not in a kit. It said it was 525x120. I'm assuming the 120 means how many chain links are in the chain (maybe I'm wrong) but what do both these numbers mean and what do I need for my bike if I want to to run stock and not screw up my speedometer or anything like that. Also, what size front and rear sprockets do I need? 16 teeth in front 45 teeth in back? And are these sprockets/chains universal as long as it is the right size I need? Forgive me, I know these might be dumb questions but hey, ya gotta start somewhere! Thanks for looking and for any help you can provide.
Below is a link to the chain I found and I will probably purchase. Take a look and see if it looks right to you or not.
EK Chain 525 Yellow MVXZ X-Ring 120 Links MVX O-ring RK | eBay
Moore.Speed, being unsure of what chain and sprockets to use can be a little intimidating. As for going with color, I think it's a great idea. My wife and I get lots of complements on ours. EK Chain (Enuma Chain) is an excellent manufacturer and makes a great product. You'll notice that Driven Chain kits are actually EK Chains, note the part number MVXZ.
Going with a kit can make it easier as you get everything you need. I read that you're new to bikes so you've got a long future of motorcycles ahead of you. Chains usually come in standard lengths of 120 links. They need to be cut (by you or a shop) to the proper length for your specific application. You can get a chain breaking/riveting tool for less than $100. I know it sounds like a lot, but you'll have it for ever and if your continue to ride, there will be more chains in your future.
Don't be concerned though about buying sprockets here and your chain there. Yes, chain's and sprockets are universal in that the spacing between the teeth and the thickness of the sprockets are the same within a group. All 530 chains are the same width, as are 525's and 520's. The differences are in the bolt hole patterns and wheel hub/shaft openings. Those differ between makes and models of bikes. So, go to where you want to buy the chain or sprockets and find your model/year of bike. I'd recommend that you stick with stock sizes for your bike as far as the number of teeth. You've already got a handful of bike.
Incognito, I searched and searched for the answer you gave me and I finally found it last night before going to bed.
IDoDirt, thanks a lot for the reply! That helped a lot. I plan on ordering from motomummy.com and I plan on going with the MVXZ or RK GXW. Any recommendations there? I will keep my sprockets the same but they offer the chains in 520 and 530 only. Is this ok? And if so, which one to go with? From what you said about 520 being lighter and all, I do not need that. I'd rather have a longer lasting chain. I just enjoy riding it and I do not race it.
Yes, I am looking for a colored chain (yellow). Ok, that motomummy website has a kit that offers the 520 GXW chain that I can get yellow for about $190. Someone before said the stock chain size was like 108 links or so I believe. Is that right?
https://www.motomummy.com/store/prod...roductid=16291
May wanna check these guys out before you pull the trigger on a chain. You can't beat it for the money and look at the tensile strength. I put a red one on my 01 Erion and have zero complaints. I cannot verify this, but I suspect they are made by RK (I ordered an extra masterlink from them because they told me their sideplates were thicker than anyone elses and no one elses would fit). When it arrived, it was a RK packaged masterlink. Go figure...
525 O-Ring Motorcycle Chain with 108 Links - Gold
