chain
Old Feb 22, 2010 | 11:55 AM
new06f4iowner's Avatar
Default chain
I do mostly commuting and some trips on weekends. I need a new chain, should i get sprockets as well? I dont want anything expensive, just something that will work and last for a while. I know there are other threads, but i just want a plain jane one.
thanks
Old Feb 22, 2010 | 11:56 AM
forgot to mention...i have an 06 f4i
Old Feb 22, 2010 | 12:22 PM
ssweetbro's Avatar
New sprockets wont effect wear in any noticeable way, unless you get an aluminum sprocket. It would effect acceleration and top end. Choose your gearing for what you want.
Old Feb 22, 2010 | 01:22 PM
teko1020's Avatar
Say what? Whenever you are replacing sprockets or a chain you should always replace them both. Get a kit, it will save you some money.
Old Feb 22, 2010 | 02:18 PM
ssweetbro's Avatar
Hahaha, no, what I was saying is that changing gearing wont effect how a chain wears. Sorry.
Old Feb 22, 2010 | 02:28 PM
any specifics on what i should prolly go with?
Old Feb 22, 2010 | 02:38 PM
teko1020's Avatar
16/46 525 with 108 links.
Old Feb 22, 2010 | 02:44 PM
ssweetbro's Avatar
Specifics as in brand? Eh, RK is a trusted brand, but any company you go with, the more expensive chains will be made of better materials which will last longer. Cycle Gear's "Orbit" brand is a repackaged name brand, so not a bad option.
Old Feb 23, 2010 | 09:56 PM
Da11en47's Avatar
If you use Ebay check out the seller Moto-Heaven. I have asked numerous questions and eventually ordered a set of sprockets and a chain. The chain was the cheapest I found anywhere.
They answered all my questions, arrived in 2 days, and even cut my chain. Nothing but a good experience so far...I will hopefully install everything in a few weeks.
Old Feb 23, 2010 | 10:57 PM
Aken's Avatar
July 2008 ROTM
Definitely order as a kit. Or even OEM equipment is perfectly fine if you get it as a set (aftermarket is usually cheaper, though). I wouldn't change your gearing - you don't need it for the type of riding you do. Stick with 16 / 46.
