CCT MAYBE OR DID I REALLY SCREW IT UP?
Ok guys noob here, so i could really use your help.. I dropped the bike landed on its left side. so i broke the stator cover and lost all the oil bent a clip on and broke the top triple tree. So I finally got all the parts replaced and started it up but the motor rattles pretty bad from idle (after its warm)all the way up in rpms. Is it possible the cam tensioner got messed up when it hit the ground? and its just so loose that it rattles like crazy? could really used some help so any ideas are appreciated.. Thanks
RE: CCT MAYBE OR DID I REALLY SCREW IT UP?
I don't think an impact would cause damage to the CCT, it's just a spring that maintains tension on the piston. Chances are something didn't get bolted back up when you serviced the bike, go through all your fasteners, hoses, etc, look for loose parts.
good luck
the blonde weasel
good luck
the blonde weasel
Thanks for the replies... the rattle sounds like it is coming from the right side top of the motor. say around where youre right knee would be. I have not yet checked the bolts on the exhaust will do that tonight after work.. all my plastics are off the bike so i know its not those just being loose. but i am gonna go thru and make sure everything is tight.
