Cct.
This probably has been covered a million time lol.
Alright I notice a nosie between 6000rpms-6300rpms. I'm pretty sure it's the cct. It almost sounds like a belt slipping or kinda like a paper ripping something like that. Is that the cct?
Is it ok to ride with that noise? I try to stay out of that rpm range.
If it is the cct how would I go about fixing it? I'm pretty good with mechanic skills and can follow directions good.
If it's not anyone know what it is?
Only way to be 100% sure of any problem is to replace a part and see if that fixed it. What you're describing sounds EXACTLY like a CCTL problem and I'm sure if you read through the sticky, you would have found people describing exactly the same thing.
