Cct.
Old May 15, 2010 | 01:06 PM
o4ep3civ's Avatar
Default Cct.
This probably has been covered a million time lol.
Alright I notice a nosie between 6000rpms-6300rpms. I'm pretty sure it's the cct. It almost sounds like a belt slipping or kinda like a paper ripping something like that. Is that the cct?
Is it ok to ride with that noise? I try to stay out of that rpm range.
If it is the cct how would I go about fixing it? I'm pretty good with mechanic skills and can follow directions good.
If it's not anyone know what it is?
Old May 15, 2010 | 01:22 PM
kowen1208's Avatar
Yep. Been covered a million times. There's a sticky on this page about it. Your questions are most likely answered in it.
Old May 15, 2010 | 02:17 PM
andymp3's Avatar
Common people...I see 3 posts on the main page in regards to CCT's and and sticky on top for the CCT...Please make sure you search or read the sticky before you post anything....
Old May 15, 2010 | 02:26 PM
o4ep3civ's Avatar
But Im not 100% sure it's the cct. Does it sound like it?
Old May 15, 2010 | 03:28 PM
kowen1208's Avatar
Only way to be 100% sure of any problem is to replace a part and see if that fixed it. What you're describing sounds EXACTLY like a CCTL problem and I'm sure if you read through the sticky, you would have found people describing exactly the same thing.
Old May 15, 2010 | 04:33 PM
vangill's Avatar
July 2010 ROTM
sticky talks about symptoms, its actually really informative
