Catalytic Converter
yo mang...toss the cat...but do it with a new slip on that comes with the midpipe.
by all means keep the O2 sensor...like was said above, for the F4i, only leans out the mixture during prolonged cruising at constat RPM, more like highway riding.
this is good, cat is bad...so instead of gutting it, just get the slip on.
i have an akra, no O2 sensor...gas mileage stinks mang...
hi jorge,
no you do not need to reprogram the ECU...but just like any other slip ons, you would eventually want to for better performance. however, if you don't, your bike will not run like a dog or anything...it just optimizes what the pipe can offer...which isn't much, like a buck fitty and a pbnj or something...no real hp.
T
T
Thanks Tahoe, I get it now.
I also have Akapovic almost new from my last 750 Gixxer, so maybe I will use it with a new middle pipe and have a good sound!
cheers
cheers
My California model came with an O2 sensor, and a cat(which is part of the factory slip on). I have seen O2 sensor eliminator kits from power commander. And they're pretty cheap, like $15.00. As posted above the O2 sensor only leans out the motor at constant speeds, so it's not needed, but If you just remove it the FI light will come on. The hp gain I've noticed with an aftermarket slip on(D&D) over the factory slip on is tremendous!!
personaly, I would just buy a NON-California ECU off of ebay and put a PCIII on it. Dont have to worry about the ECU at all, no need for cat or O2 and better performance with the PCIII....but thats just me
ORIGINAL: jorge13
Hi Air4Andy !
Your recomendation is to not to touch either the cat or the factory can ?
Cheers
Hi Air4Andy !
Cheers
No no, you can, just don't take the O2 sensor out entirely. I personally this a solution with the sensor still functioning is best, but at least use an o2 sensor eliminator like stated above. If you just pull it out, FI light will come on and cruising gas mileage will suffer.
