Can you guys help Me....
Old Nov 3, 2009 | 12:28 PM
datboigreen's Avatar
Default Can you guys help Me....
The video will explain everything plz give me a tip on whats wrong with this thanks....
http://www.youtube.com/watch?v=oidSeiZr4AI
Old Nov 3, 2009 | 02:27 PM
Junior2552's Avatar
adjust the idle screw. search through our fine forum and you will find out exactly where it is. it's a pretty easy fix, no worries mate.
Old Nov 3, 2009 | 02:43 PM
It only does it on cold starts it will slowly reach that then it starts to go back to regular. When it warms up it idles down to 1400 and its fine but like I said it starts doin this only on cold starts...
Old Nov 3, 2009 | 03:34 PM
Junior2552's Avatar
that's still gonna be the idle screw boss. mine goes to 3000 rpm, then back down to about 1100, which is where you want to be. 1400 sounds a little high to me. google it and find the placement of the screw!
Old Nov 3, 2009 | 04:00 PM
backdoc's Avatar
Idle adjustment should be on lower left side of bike just above the engine case. It should be easy to locate. It should be straight if front of you at 1:59 of your video towards the back. You should be able to reach it with the fairing on the bike.
Old Nov 3, 2009 | 04:48 PM
Joey_f4i's Avatar
You're looking for a little black **** very close to the stator cover.
I'll try and get a picture up.
To set the idle, turn the **** back and forth to the correct RPM idle.
You can adjust it with the left fairing on, it's a little hidden, but its there.
Here's a pic of where it should be, sorry bout the crappy cell phone res:
Old Nov 3, 2009 | 06:02 PM
Junior2552's Avatar
thanks Joey, saved me the work! i appreciate it!
Old Nov 3, 2009 | 06:36 PM
Joey_f4i's Avatar
Glad it helped!
Old Nov 3, 2009 | 06:57 PM
purpleslug's Avatar
if it only does it when its cold why is the bike at 190+
Old Nov 3, 2009 | 09:02 PM
Its that high because before i started recording i had it runnin to see if it got high again...
