Can you guys help Me....
The video will explain everything plz give me a tip on whats wrong with this thanks....
http://www.youtube.com/watch?v=oidSeiZr4AI |
adjust the idle screw. search through our fine forum and you will find out exactly where it is. it's a pretty easy fix, no worries mate.
Originally Posted by Junior2552
(Post 854473)
that's still gonna be the idle screw boss. mine goes to 3000 rpm, then back down to about 1100, which is where you want to be. 1400 sounds a little high to me. google it and find the placement of the screw!
Idle adjustment should be on lower left side of bike just above the engine case. It should be easy to locate. It should be straight if front of you at 1:59 of your video towards the back. You should be able to reach it with the fairing on the bike.
You're looking for a little black knob very close to the stator cover.
I'll try and get a picture up. To set the idle, turn the knob back and forth to the correct RPM idle. You can adjust it with the left fairing on, it's a little hidden, but its there. Here's a pic of where it should be, sorry bout the crappy cell phone res: http://i33.tinypic.com/b4u92w.jpg |
thanks Joey, saved me the work! i appreciate it!
Glad it helped! :D
if it only does it when its cold why is the bike at 190+
Originally Posted by purpleslug
(Post 854555)
