Can we use 600RR internals?
Old Aug 11, 2008 | 12:18 PM
Xevuhtess7's Avatar
Default Can we use 600RR internals?
Hi everyone,
I'm using a F4i to power a Formula SAE car, and am looking into high compression pistons. I have found Wiseco's 12.8:1 set, but nothing from anybody else. I saw that JE makes a 13.5:1 setup, but that is for the 600RR. Are the internals interchangeable between the F4i and the RR motor?
Thanks
Old Aug 11, 2008 | 04:30 PM
Jaybird180's Avatar
Default RE: Can we use 600RR internals?
Good question. There are a few similarities and many differences. The engine in the RR has dual injectors. As such I'm sure the top end would be different. I'd be surprised if the pistons were interchangeable.
Old Aug 11, 2008 | 11:05 PM
Xuracing's Avatar
First off why not? Bore and stroke Identical Compression identical. So the spacing cant be that different. The only thing i would check is the depressions on the pistons aside from that i think you are set. Or get a thicker HG and boost it! Why not ask the question on fsae.com? I am also on the Fsae team at my school. just out of curiosity why would you want to use rr internals anyways?
Old Aug 11, 2008 | 11:07 PM
Xuracing's Avatar
Also if you are looking for JE pistons why not just ask JE? they will tell you right up
Old Aug 12, 2008 | 08:29 AM
Jaybird180's Avatar
ORIGINAL: Xuracing
you answered your own question
Old Aug 12, 2008 | 12:06 PM
Xuracing's Avatar
true story i tend to do that sometimes haha
Old Aug 12, 2008 | 07:43 PM
Xevuhtess7's Avatar
Called JE and didn't get through, but I tried again today and I spoke with a rep. He said the wrist pins are different, so we can't use the RR pistons in the F4i. They discontinued their line of F4i pistons, thats why I was curious if the RR's would work
Old Aug 12, 2008 | 10:40 PM
Xuracing's Avatar
They make custom pistons price is maybe +/-50 dollars
Old Aug 12, 2008 | 10:41 PM
Xuracing's Avatar
and if only the wrist pins are just different then just use the RR rods as well.. you might as well if you are commited
Old Aug 13, 2008 | 07:52 AM
Jaybird180's Avatar
ORIGINAL: Xevuhtess7
More and more our bike is becoming a dinosaur.
CaNsA
Mar 6, 2011 10:51 AM
tutman6
Jul 12, 2008 10:49 PM
hellboytt
Sep 20, 2007 01:28 AM
melophat
Apr 4, 2007 10:59 PM
abelg
Mar 21, 2007 09:09 AM
