broken key guy again
Old Apr 25, 2007 | 05:33 AM
jo3jo3520's Avatar
Default broken key guy again
ok so im still working on my ignition (you know the bike that im trying to steal from myself) and i just got an idea but dont know how good of an idea it is. i have the other piece to the key thats broken in my ignition so what i had thought of was what if i put epoxy on the end and then try to get it to stick the to the other part of the key and see if it pulls out. the only bad part is if a get epoxy anywhere other than the key im screwed.. or do any of you have any other suggestions for getting the broken key out?
Old Apr 25, 2007 | 06:09 AM
BillytheKid's Avatar
Default RE: broken key guy again
there is no way in the world that epoxy is gonna hold. The only "solution" i can think of is to drill a 0.5 mm into the root of the key and using reversed tap drill to pull it out. Still I dont think the key is thick enough to do so. You can try dismantling the whole ignition system to see if you can get to catual lock istefl from a sideways position.
have u tried grabbing the key with some fine nose pliers, then push it inside and rotate the key to the off position. In the way the key would be freed and "could" be pulled out.
Old Apr 25, 2007 | 09:08 AM
Ruftags's Avatar
did the key break off up at top or mid way?
Old Apr 25, 2007 | 03:51 PM
jo3jo3520's Avatar
the key is broken at least 3/4 of the key. ive tried to take the ignition apart but many people on this forum thought i was trying to steal a bike when i asked how to remove it so i could take it apart and get to the key. a guy had recommended torx bits and i bought some last night and tried and i have no idea if im just doing something wrong but the torx bits didnt work. they work on the 3 little screws at the very bottom on the ignition but there is 2 bigger silver screws that i cant seem to get out with the torx bits. and i know some of you are going to reply that you cant tell me because of the "ill-purposes" of other people but if you have any suggestions or ideas or how the heck to get the ignition or key removed you could always private pm me. i would really appreciate it cause i have a f4i but i cant ride the dame thing with a broken key in the ignition
Old Apr 25, 2007 | 09:24 PM
Stephens's Avatar
According to the F4i tech manual, you have to remove the triple tree. From the underside, you remove the 4 bolts holding it on and it will allow you to remove the ignition switch, then letting you dismantle it or replace it. Thats how I read it.
Old Apr 25, 2007 | 10:54 PM
jo3jo3520's Avatar
thanks man ill have to take a look at that
Old Apr 26, 2007 | 12:15 AM
Stephens's Avatar
Your welcome
mr.z28
F2 Tech
May 18, 2010 10:32 PM
EA
Jul 15, 2008 12:58 AM
be vertical
Jun 19, 2008 07:25 AM
sublyme
Sep 16, 2006 03:02 AM
