brakes
Old May 24, 2011 | 10:05 PM
new06f4iowner's Avatar
Default brakes
riding today and i hit the brakes and then i notice i feel a bad vibration, well its happened a few times, but its like i can feel the circles in the brake rotors. I dont think my brake pads are bad but maybe the rotors worped?
Any other ideas?
Old May 24, 2011 | 10:29 PM
DrAwkwArD's Avatar
Rotors could be warped but you could also have some bad pad build up on them. Take the front wheel off the bike and get the rotors off. After you have the rotors off hit them with a high grit sand paper (or if you want to be professional about it get a brake hone, but sand paper is fine) and go all the way around the face of the rotor both front and back. Don't touch the rotor with your fingers and reinstall and see how they feel.
Before you do this you can check for rotor runout with a dial gauge but not everyone has one of those so "eying it up" may work for you.
Good luck.
Old May 24, 2011 | 10:35 PM
F34Me?'s Avatar
Most likely a sticky caliper. Break it down and inspect all the bits for wear/damage. Make sure everything is clean and lubed where needed. Use high temp grease and make sure you don't get any in places it doesn't belong! Probably worth inspecting/cleaning the pads and rotors while you are at it.
Old May 25, 2011 | 12:15 PM
yunebug's Avatar
Does the vibration decrease as you come to a full stop? That's a surefire sign that the rotors are warped. If the vibration is constant no matter what speed, then it'd be something else.
Old May 26, 2011 | 07:08 AM
When I hit the brakes now it doesn't start rightthen...it is gradual and gets worse.
Old May 26, 2011 | 09:52 AM
yunebug's Avatar
Gets worse as you come to a stop (i.e. as the wheel spin slows down)? Then it's warped rotors. Solution? You can fix them or buy new ones.
Old May 26, 2011 | 02:30 PM
Yea, it gets worse as the tire slows....how do I fix them without buying new ones?
Old May 26, 2011 | 02:38 PM
yunebug's Avatar
I've heard/read of putting it on a machine that measures the warp. Then if the rotor warp is within tolerance, they can machine the waves out so that it's straight. Yes, this means thinner rotors. That's the negative side of it, I suppose.
My suggestion - buy straight rotors. You can install both F4i and F4 rotors and there are plenty available. I figure you shouldn't skimp on things that will save your life.
Here are a few I found on eBay:
HONDA CBR600F4I CBR600 CBR 600 FRONT ROTORS *FREE SHIP* | eBay
HONDA CBR 600 CBR600F4 F4I FRONT BRAKE ROTORS pp | eBay
Honda CBR 600 F4i front rotors discs | eBay
EBC PRO-LITE FRONT BRAKE ROTORS HONDA 01-06 CBR600 F4i | eBay
With the used ones, you WILL want to ask and document the seller confirming that the rotors are, in fact, straight.
Old May 26, 2011 | 06:51 PM
ye, i guess ill deff be on the look for some. Thanks
Old May 26, 2011 | 08:40 PM
MadHattr059's Avatar
You can check for warp by laying the discs on a piece of heavy glass or granite.
Run a set of feeler guages under the edge between the disc and the surface it's on. Your run-out is ....(biggest guage you can slip under anywhere) x2= run-out.
Ern
Nytmr
Dec 21, 2013 09:16 PM
CBRInfantry
Feb 7, 2011 09:42 PM
hopz
Jun 4, 2009 01:28 AM
radvoem
Dec 28, 2008 08:38 AM
