Brake torque specs
Hey everyone, just finished changing out my front and rear pads with ebc hh sintered pads. Does anyone know the torque specs for the two Allen head bolts on the front calipers to remove the pads an the two long bolts on the rear along with the Allen head bolt with the setscrew on the rear. I tightened them by hand an want to be sure. I don't have my manual yet so just wondered if anyone knew. Thanks!
The PDF is linked in the manuals thread. I've never actually used a torque wrench on the allen headed bolts holding the pads in the calipers, and I torque pretty much everything on the bike. They are so small that the only thing to really worry about is over tightening them.
Thanks so much. I've been checking everything after every ride and seem to be ok. Rode 200 miles on the parkway today also no problems. I'm still having trouble locating the PDF manual files on this forum. I can't find them anywhere.
Thanks for the help. Found the manual thread. I only had to take the Allen head bolts out on the front and slid the pads out. I guess my main concern were the two bolts holding on the rear caliper but all is good now. Didn't realize how easy motorcycle brakes were, glad I took the time.
Torque wrenches are for inside the motor, outside the motor you just do it to feel...
As an example if you torque the rear axle to spec on many bikes it will bind the rear wheel to the point it causes parasitic drag and slows down the rotation of the wheel not to mention puts additional lateral stress on the bearings causing premature failure. If you simply tighten the axle nut until it starts to slow down the rotation then back it out a bit to free it up it is still more than adequate to keep everything tight & safe without any extra harm.
As for the EBC HH pads WHY??? I wrote an article about my brake pads experiences over the years here and for those that don't know it the HRC race pads for the RC51 were never actually made for the RC51, but the F4i specifically because the RC51 was never races in supersport only the F4i. In superbike trim the RC51 received Brembo brakes, but since the HRC race pads for the F4i also happen to fit the RC51 OEM calipers they became the pads of choice all over the world until they sold out. At any rate the article explains why EBC pads suck
ROGUE Brake Pads Information Page
It's like you owning a ford and me a Chevy and me telling you how mercron trans fluid sucks and how great dexron trans fluid is. Who the hell cares, it's apple and oranges. Different strokes for different folks...
LDH- What exactly is premature bearing wear? I've been torqueing my rear axle nut to spec for over 7yrs and 61,000 miles now and Im still on original everything. Perhaps your idea is good for a track bike that sees very limited time in between tightening and checking things but for a street bike your advise is going to hurt someone some day.
tele- LDH is correct in observing that EBC's HH's aren't the best pads availible. [I myself prefer oem pads on the f4i for street/strip dual duty] No need to get upset that he pointed it out. Means next time you can make a more informed decision. And while they might not be the best, they are still perfectly acceptable pads that won't give you any trouble.
