Bolt/Nut sizes
Old Jun 13, 2009 | 01:30 AM
ibiggers's Avatar
Default Bolt/Nut sizes
I have been looking around for this but haven't had luck locating it in the Factory Service Manual:
1. I need the bolt size both heads of the rear axel,
2. The Front Sprocket Nut Size.
Thanks, I have the torque specs, but I don't see where in the manual it says what sizes they are. Thanks for the help!
Old Jun 13, 2009 | 02:12 AM
jp_greenville13's Avatar
just the head size or the actual measurements of the bolt? If it's just the head size it's likely not published. If you're not proficient with a wrench just guess and check
Old Jun 13, 2009 | 08:19 AM
ibiggers's Avatar
That would be great advice if you realized that the sizes of those bolts were larger than the typical socket sizes used for normal tinkering around the house and simple mechanical maintainence. I actually need to buy the larger sockets and don't feel like buying more than I actually need at $5 a pop.
Old Jun 13, 2009 | 10:26 AM
Oh! duh. lol.you could put an adjustable on them and measure them if you don't have a caliper. sounds like sockets you might want to buy at a place like harbor freight as well as you wont be using them very often.
Old Jun 13, 2009 | 01:57 PM
cman9toes's Avatar
Do you have a honda tool kit? The wrenches are there with the size stamped.
I think 22 and 24, if you dont have a kit I'll check for you when I'm at the house.
Old Jun 13, 2009 | 07:18 PM
dave ls1's Avatar
The front is a 22mm
The rear is 22mm on the left and 27mm on the right.
I literally went to the garage and checked, as I just finished a couple projects and had to remove my wheels too.
Old Jun 13, 2009 | 08:25 PM
ibiggers's Avatar
I actually used the Honda tool kit. And the front sprocket bolt was 14mm so I already had that. Thanks for the posts. 520 -1/+2 Install went great love the change!
Old Jun 13, 2009 | 09:43 PM
cman9toes's Avatar
Glad you got it.
Alot of people forget about the tool kit. I don't always use it, but I do reference it for socket sizes.
Taw1985
Mar 20, 2013 12:02 AM
kazspeed
Mar 7, 2011 01:36 PM
Memphistn3000
Oct 18, 2008 02:08 AM
FireStourm
Mar 24, 2008 10:29 PM
Chunk3rs
Aug 24, 2007 12:02 AM
