Need some bolt/nut sizes.
Old Aug 23, 2007 | 01:22 PM
Chunk3rs's Avatar
Default Need some bolt/nut sizes.
Hello!
I think this is my first post on this forum, I'll have to check after the post is done *edit* yep, first post! */edit*. I bought two CBR600F parts bikes (one wrecked) about a month ago and am currently turning them into a semi-restored/semi-streetfighter bike, and just have a few basic questions.
I have the Clymer manual for the bike(s), but I can't find anywhere if it says specifically what size the bolts I need off are, and don't want to go buy a bunch of expensive sockets just for the two I need. The bolts/nuts I don't have the right size socket to remove are:
The middle bolt in the top triple, if I had to guess I'd say it's a 30mm, but I'm not sure.
Also the nut holding the clutch assembly all together, I think it's a locking nut. I'm guessing it's a 26mm, can anyone confirm that?
Thanks!
-Matt
Old Aug 23, 2007 | 02:02 PM
rrasco's Avatar
Default RE: Need some bolt/nut sizes.
I will take a look when I get home, but I dont think I have a socket that big either.
Old Aug 23, 2007 | 02:34 PM
michigan_313's Avatar
mmm.... 20mm on the clutch and i believe 24mm or 26mm on the stem nut.
Old Aug 23, 2007 | 05:51 PM
Chunk3rs's Avatar
Hmmm, well I have up to 25mm sockets, and both my clutch and triple nuts are bigger than those.
Maybe I'll have to just figure out a way to measure them.
Old Aug 23, 2007 | 10:49 PM
well, i was partially right. the numbers i gave you are thread dia.
but, the stem nut is 30mm. and i would venture to say the clutch is 26 or 27 but since i can't find my spare i can't say for sure. the oem manual doesn't have socket sizes listed.
i can't remember how big the locknut is for the clutch, but if you can see it and compare to the stem nut, you won't be far off. it has to be under 30mm. you know, come to think of it, it is probably a 27 since the only other large socket i have isa 24mm.
Old Aug 24, 2007 | 12:02 AM
Chunk3rs's Avatar
Alright!
30mm is what I was thinking, thanks for confirming that. Since I like to have (semi-good) quality tools, it's just too expensive to go out and buy 5-6 sockets when I'll only use two of them, most likely ever.
Thanks,
-Matt
Taw1985
Mar 20, 2013 12:02 AM
kazspeed
Mar 7, 2011 01:36 PM
ibiggers
Jun 13, 2009 09:43 PM
Memphistn3000
Oct 18, 2008 02:08 AM
FireStourm
Mar 24, 2008 10:29 PM
