bike wont start. no lights but shows high beams on.
Old 11-16-2008, 10:07 PM
c0zgrove's Avatar
Default bike wont start. no lights but shows high beams on.
So Im having this really weird problem with my bike right now. When I turn the key on, it shows that my brights are on but neither headlight is on. When I switch to low beams, still no lights at all and still shows that high beams are on. Also, you cant hear the fuel pump prime and Ive already tried to push start it just to make sure. Still no luck. Fuses are all good, battery is good, no visible disconnections or damages to any wires that I can tell. Ive had the problem in the past where the start button sticks and the bike starts but the lights dont come on; Ive already checked for this and it doesnt seem to be associated. Anyone have any ideas?
Old 11-16-2008, 10:52 PM
FLYOU's Avatar
Default RE: bike wont start. no lights but shows high beams on.
i know i know i know!
that will cost you $5 for the answer
Visa, Mastercard, and paypal accepted
Old 11-16-2008, 11:00 PM
oodie's Avatar
February 2009 ROTM
Try checking harness making sure its grounded. That what it sounds like
Old 11-16-2008, 11:02 PM
FLYOU's Avatar
dammit. and i was about to get 5 dollars you son of a bitch
your front wiring harness isn't grounded properly. common problem with the F4i.
Old 11-16-2008, 11:13 PM
oodie's Avatar
February 2009 ROTM
I'll edt it if you split the 5 with me.
Old 11-16-2008, 11:31 PM
maldy21's Avatar
this sounds kind of familiar....
Old 11-16-2008, 11:33 PM
thirdgenlxi's Avatar
Ironmang
ORIGINAL: FLYOU
This is true! Unplug your headlight wiring harness from the main harness (connector next to the left side ram air tube) and look for the green wire in one of the very end cavaties. I'll bet you'll find it doesn't look too good, and quite possibly melted the plastic on the connector a bit. Had the same thing with mine at one time... I just took the wire out of the connector and put 2 insulated spade connectors on them to connect them seperately outside of the connector. Never had a problem since!
Old 11-16-2008, 11:36 PM
FLYOU's Avatar
dammit, my 5 dollars is gone forever.
thirdgen, you never help me out! now you randomly appear help out this cat. you suck! haha
Old 11-16-2008, 11:38 PM
Ironmang
ORIGINAL: FLYOU
What'd I do??
Old 11-16-2008, 11:39 PM
FLYOU's Avatar
ORIGINAL: thirdgenlxi
ORIGINAL: FLYOU
What'd I do??
had a real weird issue (that's still an ongoing issue) with my fan and cooling system. I PM'd you about it a couple weeks ago. Just wanted a 'professional opinion' on the matter. wanted your advice cause i'm worried my bike is going to blow up in the very near future
Quick Reply: bike wont start. no lights but shows high beams on.
