bike wont start
Old Sep 8, 2008 | 06:15 PM
kyledm18's Avatar
Default bike wont start
well i went for a ride the other night it ended up to be almost 200 miles and i got home and parked it in my house as usual. i went out early this evening planning to go to walmart to buy a gps and i went ti start the bike and i turned the key, waited then flipped the injection switch and heard no whine, so i looked and went to torn off my highbeams and it just started clicking, mostly the bike wont prime, its got no headlights and it clicks from this little square thingy that says OMRON G8MS-H68 12V 20A 0576D6, any help greatly appreicated thanks
Old Sep 8, 2008 | 09:34 PM
FLYOU's Avatar
Default RE: bike wont start
how old is your battery?
Old Sep 9, 2008 | 08:28 PM
kyledm18's Avatar
not that old, it turns over fast and fine so i dont have a clue what the problem is
Old Sep 10, 2008 | 09:43 AM
birdstrike's Avatar
First to eliminate the battery try jumping the battery from a car. If the bike starts you need a battery, or potentially a stator
If that doesn't work try pulling the fuse to the headlight. They can short sometimes causing your problem. If the bike starts replace the lamp, and check your wiring to the lamp (make sure it hasn't melted the insulators back
Old Sep 21, 2008 | 08:50 PM
kyledm18's Avatar
well i finally got up and looked at the bike and there is a fuse linking 2 wires to a relay together and the headlights look to be an h4 with the big circle around them chopped down to fit in, im gonna look into it more and see if i can fix it and if i cant off to the shop it goes
willie72
Oct 26, 2022 04:53 PM
aperez18
Feb 19, 2014 11:13 PM
CBRbanas
Mar 3, 2012 11:52 PM
tagger609
Jun 27, 2008 02:09 PM
demonchild
Jan 31, 2008 01:42 AM
