bike died mid-ride...HELP!
Old May 13, 2008 | 09:38 AM
ellusion50's Avatar
Default bike died mid-ride...HELP!
here's the deal, mid ride about 30mph... bike starts sputtering like it doesn't have gas. but it does. everytime i hit the throttle, it gets worse. i had to idle the bike to a gas station in 1st gear, filled up the tank. then when i tried to turn it back on, it wouln't turn over like the battery was dead. my components came on, my clock is a different time now. possible alternator issue or could the battery be dead?
any info would be great!
Old May 13, 2008 | 10:19 AM
ampfp's Avatar
Default RE: bike died mid-ride...HELP!
definitely sounds like battery connections are loose. Debug that before the other problems. get a voltmeter/multimeter to debug the rest.
Oh and even if they look decently tight, just take the connections off, and make sure the battery terminals and the connectors are shining metal and not dull oxide color. scrape them if they're the latter.
Old May 13, 2008 | 01:00 PM
f4iman's Avatar
Do bikes have O2 sensors?, becasue that sounds like what that would be. If the battery died, who wouldnt have been able to drve it in any gear. That also goes with the loose connection, you either have power or you dont.
Old May 13, 2008 | 07:29 PM
scott_1662's Avatar
hey man i just had the same problem get new plugs ! my plugs were gone and i had the same problem plugs are costly tho ! haha !
Old May 13, 2008 | 08:08 PM
kdub41's Avatar
hey man this has happend to me but on a dirt bike and it was from my spark plugs if they are going bad this will happen
Old May 14, 2008 | 09:43 AM
02cbrf4i4u's Avatar
Id say Battery...sounds like the same thing that happened to me.
Old May 14, 2008 | 10:12 AM
wishin4600rr's Avatar
it sounds more like the battery than spark plugs. How old is the Battery? Have you changed it recently? If so recheck the connections and if you think they are tight, I would tell you to tighten them a little more (use common sense). When you turn the key to the "on" position and try to start does it sound as if it doesn't have enough power?
(Your simptons that you stated happened to me before and in my case it was that the connector's weren't securely tied down to the battery).
Info on spark plugs: http://www.aa1car.com/library/cm1196.htm
http://www.helium.com/items/987661-s...devices-engine
Old May 14, 2008 | 03:02 PM
dankryder's Avatar
Sounds like spark plugs are fouled. Battery is either dead or not dead theres no kind of have a battery.
Old May 14, 2008 | 04:47 PM
CBR_Rod's Avatar
Bad spark plugs won't reset a clock.
dad0507
Mar 24, 2014 02:35 PM
EViR
Sep 11, 2012 06:58 PM
Boxdgm
Aug 1, 2011 07:46 PM
codered
Jun 16, 2011 03:37 PM
JAstel
F2 Tech
Aug 30, 2010 10:46 AM
