Best Windscreen?
Puig double bubble showed up. They've changed the name and it's now called a "race screen" or some-such.
Time to install 15 minutes exactly. Very easy to do. 6 allen head bolts into rubberized Lord
mounts.
I have to say this is the most worthwhile upgrade I've done so far (K&N, Power Commander, Yosh Pipe).
At speed the turbulence around my head is gone. Just smooth air. Quieter too. It sits 3.5cm ( 1 3/8") higher than the stock
unit
The only negative is that the plastic isn't as visibly perfect as the OEM screen. There are a few waves in it but
overall it's fine. It's too dark to see through most of the time anyways.
9/10
B.
mounts.
unit
9/10
B.
zero gravity double bubble dark smoke here. Pretty much the same what the guy above said. With the stock one I had to lie down on the tank and look through the windscreen on speeds above 130 mph becuase it felt like the wind is going to tear my head off. With double bubble one you can go 150 and still lookabove it without much discomfort. Also I noticed that bugs spotis now moved slightly above, if the highest density of bugs was right in the middle of your visor, now it ison the forehead(you still get bugs on your visor, but noticeably less).
I wish it was a little shorter though. 1/2-1 inch shorter would be perfect. But stillI like it much more than stock one.
I too have the zero gravity dble. bubble wind screen lite smoke and it's great. picked it up from chapparrel for $88 shipped.Had to get the screw kit cause the stock screws are secured by imbeddeed bolts built into the stock screen. Installation 15 mins. worth the investment.
[/align]
um. . .the stock screws are just rubber well nuts that you can reuse if they werent' deformed too much
ORIGINAL: Arthur
[/align]
[/align]
