Battery Tender Jr.
Old 11-06-2008, 03:18 PM
RBX13's Avatar
Default Battery Tender Jr.
I'm not home so I can't check my battery but..........which one do we want? The 12 volt or the 6 volt?
Also, has anyone used the Battery Tender Jr. before and if so,what was your experience? My bike is having a hard time cranking over lately so I thinkI might need one of these. It's a 06' with the original battery. Whatdo you think?
RBX13
Old 11-06-2008, 03:34 PM
Default RE: Battery Tender Jr.
12 volt. 6 volt systems are typically only used in REALLY old cars, or marine applications.
Also, get the one that is 1.5 A throughput... it's just the right size for MC batteries, but conveniently, works well on car batteries as well. I love that you can leave these things sitting overnight, the fact that they automatically shut off is a godsend.
the blonde weasel
Old 11-06-2008, 03:36 PM
oh also, you'll probably find that charging your old battery works well for about a week or two, then it will give you trouble starting again. If that's the case, the battery needs to be replaced. I've always had to change batteries on my bikes about once every two years.
Old 11-06-2008, 04:00 PM
Stephens's Avatar
Not necessarily have to change your battery, I have the original battery and I have left my lights ( exterior red lights) on and killed my battery numerous times and put it on the charger and its just like brand new again. My battery is 2002, so thats 6 years old. For the winter, I start my bike up once a month and let it run for about 30 minutes and the I put the charger on it two days before I ride it again in the spring. And my bike still runs great.
Old 11-06-2008, 05:39 PM
RBX13's Avatar
Thank you. I'll get one and give the battery a charge and see what happens.
Old 11-06-2008, 06:29 PM
LoneWolf04's Avatar
I'm using the battery tender junior and mine is rated for I believe .9amps. I did this because my battery stated it wanted a that amp charge for slow charging. I leave it plugged in all winter long, will be putting it on probably next week as I believe this was going to be the last good day of riding. but who know, its michigan.
Old 11-06-2008, 06:43 PM
PlayfulGod's Avatar
I have a BT JR. It works great except on a dead battery, then I have to use a big charger to charge it some then the tender works great.
Old 11-07-2008, 10:55 AM
JSmith319's Avatar
I've got the same 12v charger, and it's worked great without a hangup.
Old 11-07-2008, 11:03 AM
MidnightG35X's Avatar
I use the VDC batteryminder plus (http://www.batteryminders.com/batter...o-p-16134.html) It works just like a battery tender jr. except it also conditions the battery by desulfating the posts. It runs $50 online (http://www.pacificbattery.com/batteryminder.html). Very highly recommended.
Old 11-07-2008, 11:51 AM
fishfryer527's Avatar
I'm on my 3rd battery, you are probably due for a new one. The tender (12v) should help with longevity.
Quick Reply: Battery Tender Jr.
