Anyone have a Valve shim kit?
Old Mar 15, 2009 | 07:06 PM
MC_spirited's Avatar
Default Anyone have a Valve shim kit?
I am going to be disassembling the bike for cleaning and maintenance. Need to do some wiring and electrical things, a cooling system overhaul, fluid change and i have to install this APE CCTL that i bought like last year. The bike has like 37000 so i think its time for me to get the valves right.
I know some forums have kits that the members use when they need to do their clearances. Anyone have a shim kit that I could use? Anyone know where i can get a kit if nobody wants to pony one up? thanks for the read.
Old Mar 15, 2009 | 09:37 PM
jonld's Avatar
Hot Cams kit. no one is just going to let you use there kit as shims are quite expensive. The 80 dollar hot cams kit is a good buy though over ordereing OEM ones.
Old Mar 16, 2009 | 09:26 AM
jkh421's Avatar
You don't need a kit, measure your clearances do some simple math and go order the shims you need through honda, remember though going through honda the shim sizes have to end in 0,2,5 or 8 such as 1.90, 1.92, 1.95, 1.98. try to get the number as close to spec as possible there are several shim sizes that will work but only 1 will get you right on or near the number
Old Mar 16, 2009 | 02:04 PM
bwayers's Avatar
i was about to say the same thing
and you only need shims if your valve clearance is actually off, usually your clearance is good if your bike has been running fine
Old Mar 16, 2009 | 07:17 PM
well i got the bike last year with 26000 miles and it has 37000 miles now. I can feel that it is lagging under 4000 rpms when i leave lights and whatnot. I just bought the kit.
Maybe i assume that there are other decent trustworthy people who would lend out tools and the whatnot to other trustworthy decent people. Maybe i am just expecting too much out of society.
Old Mar 16, 2009 | 10:29 PM
jonld's Avatar
Shims arent tools, they are parts. they cost $6 or so a piece. The problem with measuring and ordering is if they've gotten tight like mine have in the past. you can't just measure and order, you have to change them with some that will give you clearance and then re-measure. The kit allows you to measure and go. the only downside Ive had with the kit is there are only 4 or 5 of each which sometimes you need more. I had to grind some down.
Old Sep 14, 2021 | 10:47 PM
rover528's Avatar
Registered Users
I'm in need of some advice.
I had my head off my 05 cbr600f4i to repair a stripped spark plug.
While setting the head back on the motor and threading the cam chain through it's appropriate slot somthi g got hung up and while i was tilting the head to see what was hung up 2 of the buckets fell out on the floor and one of the shims fell out. Now the head is sitting on the motor and i found the shim but i dont know which was which. They are both intake buckets. One shim is 2.08mm and the other is 2.06mm.
What would you recommend for me to do. Are the shims close enough in size that it wont matter. My next step was to check the valve clearances but im trying to save myself some extra steps.
Old Sep 15, 2021 | 02:21 PM
74demon's Avatar
Put it together and check the clearances. That's all you can do. Take the extra steps and check/adjust all of them.
Old Sep 15, 2021 | 04:26 PM
rover528's Avatar
Registered Users
Thanks. I will take those steps.
(951) Baby Shortee
Feb 14, 2012 08:57 PM
shok47
Aug 26, 2011 02:46 AM
josh123
Oct 8, 2010 07:09 PM
berga
F2 For Sale / Trade / Wanted
Apr 25, 2010 08:52 AM
Clorox09
May 23, 2008 05:51 PM
