Am I the only one? Pegs keep scraping
Old Jun 9, 2009 | 10:24 AM
boredandstroked's Avatar
Default Am I the only one? Pegs keep scraping
This started when I was riding two up. Going threw turns I was throwing sparks from the feeler tips on my pegs hitting the ground. I thought it was because I couldn't get off the bike enough with a passengers arm in the way holding onto the tank. Problem is I do it all the time by myself now too, and Im as far off the bike as I can get. I broke both the stock pegs off and had to get some bolts to replace them. The bolts aren't breaking but the right side one [its a little longer so I don't hit my muffler, that would be no fun] did bend last time it touched down. My only real complaint with this is how much it can upset the bike if Im not thinking about it and/or weighting my inside foot too much.
Am I the only one with this problem? Will rearsets help at all?
Old Jun 9, 2009 | 10:27 AM
some guy #2's Avatar
...Yes
Old Jun 9, 2009 | 02:21 PM
purpleslug's Avatar
you need to tune your suspension to your weight and yes rearsets will help the problem. i know on the rear you dont want the bike to travel more then 36mm from when its fully extened to when you sit on the bike in a normal positon. i for got the front i will go look at my notes from when i tuned mine in last and let you know.
Old Jun 9, 2009 | 03:07 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Think some of you guys missed the "two up" part. It will be damn near impossible to get your suspension right for 2 up riding. Rear sets will help and I believe on some models you can mod the existing stuff to get the pegs up and back a little. There's a how-to here on that somewhere.
In the meantime I suggest a couple things:
1) girlfriend needs to lose some weight (but you gotta be the one to tell her)
2) stiffen up your front and rear preload before riding 2 up. A couple turns on the front and 2 notches on the back to start ... if still too squishy then a couple more. This will make the bike really jumpy without the extra weight so you gotta be careful by yourself. Really stiff suspension will bounce your *** in the ditch real fast.
Good luck!
Old Jun 9, 2009 | 04:05 PM
Aken's Avatar
July 2008 ROTM
I rarely scrape pegs when riding two-up. And if I get close, my toe scrapes first so I know where it's at. Either you're riding all crazy like, or your bike is lowered.
Old Jun 9, 2009 | 04:38 PM
purpleslug's Avatar
Good luck!
My stock springs are all most all maxed out on my bike and i weigh 198 lbs. so putting to people on your bike well i know thats well over 200 lbs so just tell her to get a bike lol or go buy new springs front and rear for your bike i know fronts are about $100 each give or take $20 never checked rear because its good for me till i get to about 220-230 lbs.
Old Jun 11, 2009 | 01:33 AM
I've had the bike since new, I worked at the dealership. It is not lowerd. I scrape by myself, not just with a passenger. The girlfriend does not need to loose weight and she has her own R6 to ride. I think I'll focus on suspension setup and body position a little more before I fork over big money for rearsets.
Old Jun 11, 2009 | 02:32 AM
Aken's Avatar
July 2008 ROTM
Yeah, scraping pegs should be a rare event. Two-up it's understandable because you don't have the lower center of gravity, but by yourself it should happen very infrequently.
By saying you're as far off the bike as you can get, no offense here but I doubt it.
Have you ever done any track days? You should if you're serious about wanting to push some limits on your bike. And it'll help with the scraping
Old Jun 11, 2009 | 02:59 AM
VTcbr's Avatar
How much does your Girlfriend weigh?
no offense pal but that's probably the problem.
