Akrapovic Gas Guzzler
Old 08-13-2007, 04:47 PM
amnesia's Avatar
Default Akrapovic Gas Guzzler
After I put an Akrapovic slip on on my stock '05 F4i (no PC), my gas milage dropped from ~240 km/tank to ~200 km/tank. Is this usual for a slip on?
Old 08-13-2007, 08:44 PM
rolandk's Avatar
Default RE: Akrapovic Gas Guzzler
Does the bike run any better or worse? I'm guessing the pipe changed how your bike is running and you now need a PCIII with a map for the Akra. I'll be doing the same with my bike in a few months, can't wait.
Old 08-13-2007, 11:17 PM
holly hell, how did you pull off 240 km per tank. My 04 is bone stock and i hit the reserve at 160 km.
Old 08-14-2007, 12:08 AM
RojerLockless's Avatar
wow 160km? my 05 will do 150MILES per tank pretty easy..
Old 08-14-2007, 09:34 AM
Hayden06F4i's Avatar
ORIGINAL: RojerLockless
+1
Old 08-14-2007, 09:37 AM
Tahoe SC's Avatar
you got rid of the O2 sensor didn't you?
Old 08-14-2007, 12:50 PM
amnesia's Avatar
Actually, it's non Californian and therefore doesn't have an O2 sensor. The bike runs pretty much the same with the pipe (maybe slightly more power) - just sounds a lot better. All my researchsuggests that it's notnecessary to run a PCM with a slip on. Anyway, I would think that the unrestrictedsilencer should increase the airflow and lean the mixture if anything.
Old 08-14-2007, 11:29 PM
65ShelbyClone's Avatar
Which is 240km just like amnesia was getting.
Amnesia, are you sure you're not rolling on the gas more often now to hear the new pipe?
Old 08-14-2007, 11:35 PM
Yeah that's what I was thinking as well
I have the same slip on, andI get 200-240km before that gasindicator comes up (which means 30 more km tilltank isempty). I have better mileage in the city than on highway, in the city its usually 2-4k rpm, and on highway its 6-8k.
Old 08-15-2007, 01:22 AM
Stephens's Avatar
I have a Two Bros. and its loud and I like to hear it also. I ride around town anywhere from 6K-10K and it eats up the mpg. Ride at lower rpms and you will see a difference, but it only costs me like 10 bucks to fill it up, so I don't really care about my mpg.
Quick Reply: Akrapovic Gas Guzzler
