Airbox resonators??
Old May 15, 2010 | 03:24 PM
skameigh's Avatar
Default Airbox resonators??
Ive searched but havent found any relevant information on this. The intake resonators (the triangle shaped things on top of each air duct), Are there any benefits in removing these and sealing the holes?
Im doing the airbox mod this weekend (T valve fitting) and while Im in there, i figured I could remove those things if not needed.
Any insight welcome. Thanks!
Old May 15, 2010 | 03:37 PM
kowen1208's Avatar
Your engine will be a little bit louder. I've heard there are very slight power increases, too.
Old May 15, 2010 | 04:04 PM
skameigh's Avatar
Cool I wouldnt mind a little more engine sound Any other insight guys? Thanks for the post
Old May 15, 2010 | 04:32 PM
vangill's Avatar
July 2010 ROTM
intake noise is all ive noticed, maybe a lil loss in low end
nothing major
Old May 15, 2010 | 06:52 PM
JTProuhet's Avatar
i did the clean air box mod and cleaned my K&N filter yesterday, and i didnt notice any power increase at all...
Old May 15, 2010 | 07:40 PM
vangill's Avatar
July 2010 ROTM
^then your bike was already running good, thats a plus
the main thing about the clean air mod is to keep the air clean! as in no oil in the airbox, which you will only really have problems with on REALLY tall wheelies, sometimes it does do a LITTLE bit of increase. the resonators removed will do no low end increase but may do a high end, for me, all i noticed was the intake whistle and a k&n will prolly decrease low end and up the high end as well
Old May 15, 2010 | 09:30 PM
skameigh's Avatar
Yea I removed the resonators, clean air mod... putting bike together now. I alrdy have a K&N filter but i cleaned are reoiled it. I hope i dont loose much lowend... getting a custom PCIII map here in a week or so so hopefully Ill see soome decent f4i numbers...
Old May 21, 2010 | 09:12 PM
Jinkin02's Avatar
I pulled my resonators off to make more room for my projector headlight wiring harness - have not noticed any difference in performance. Not a noticable change in noise either.... not sure what those little suckers were doing?
Old May 21, 2010 | 11:36 PM
vangill's Avatar
July 2010 ROTM
there r there to decrease engine noise and also to change something in the intake velocity-something for emissions. mainly for the noise tho
Old May 22, 2010 | 12:57 AM
joelacer's Avatar
Ditto, I took mine off for the same reason. The only difference I've noticed is exactly what others have been saying, a bit more intake/throttle noise and maybe a very small boost in top end power. I for one like the extra sound. I think the F4i sounds way to docile when I compare it to my f3 figther.
