Aftermarket tail light install question
I have just puchased this item. Unfortunately it does not come with any installation instructions. So I have five wires and no clue what they do. I emailed the seller and they don't provide instructions (probably should of asked that question before buying), but now I'm stuck. Has anyone ever installed one of these or similar?? I'm unable to post the full ad but if you go to www.ebay.com and search 200064620384 you can see the whole ad if that helps.
var ss0ImageUrls = descImageUrls = [[ 'http://images.channeladvisor.com/Sell/SSProfiles/82000069/Images/3/STC-3076LED-K.jpg' ]];
var hostedimageSRc= 'http://images.channeladvisor.com/Sell/SSProfiles/82000069/Images/3/STC-3076LED-K.jpg';
writeHostedImage();
View larger picture
price:
US $66.95
[hr]
Ended:
Jan-02-07 19:18:08 PST
[/align]
Shipping costs:
To Canada -- US $42.99
Standard Int'l Flat Rate Shipping
Service to Canada
(moreservices)[/align]
Ships to:
Worldwide
Item location:
Fast delivery,great customer care, United States
Buyer:
[hr]
You can also:
Email to a friend | Sell one like this[/align]
Listing and payment details:
HideShow
writeHostedImage();
View larger picture
price: US $66.95
[hr]
Ended:
[/align]
Shipping costs:
Service to Canada
Ships to:
Worldwide
Item location:
Buyer:
[hr]
You can also:
HideShow
I'm not exactly sure how it's going to work, but it's led with two tone lights, so you should probably have 3 leads coming from each side, one negative, one for the amber and one for the red. I would connect the positives for your turn signals from the harness to the amber, the positives from your brake/running light (probably best to do one side each) to the leads for the red LEDs and then the two negatives from the harness for each side to the respective negative LED.
i would guess that the two yellow wires are your turn signals, the blue is the running light, and the red is the brake light. From there the black could just be a negative.
O.K. So using a 9 volt battery i have determined that black is ground, the blue wire coming out of the right side bulb hole is right turn signaland the yellow wire coming out of the right side bulb hole is the left turn signal. The remaining colours black yellow and red are grouped together in some kind of yellow plastic connector (it doesn't plug into anywhere on the bike). Any ideas.
hey man i had the same problem with the same tailight i believe by what youve said. I bought this from autozone online and it worked great...
MSD/6 pin individual weathertight sealed connector (8170) | Electrical Wire Connector Kit | AutoZone.com
