Adjust rear brake ?
Old 10-15-2008, 02:41 PM
John Mellencamp's Avatar
Default Adjust rear brake ?
How do you adjust the rear brake . As in the picture I loosened the bottom nut but when I turn the top nut it just turns the rubber out of shape .
Old 10-15-2008, 02:45 PM
jonld's Avatar
Default RE: Adjust rear brake ?
The picture is unviewable.
Old 10-15-2008, 02:50 PM
Maybe this will work .
[IMG]local://upfiles/30073/E94C27A98F15421CAD2F352C74C5C40B.jpg[/IMG]
Old 10-15-2008, 03:17 PM
JeremyGSU's Avatar
What's a rear brake?
Old 10-15-2008, 03:22 PM
lkngood's Avatar
Yeah - I thought with Sport Bikes all braking is done with only the Front Brake and Engine Braking for noral stopping situations not for panic/emergency stopping
(Downshifting the gears - one at a time - matching the rpms to help with the braking while using the front brake).
Old 10-15-2008, 03:25 PM
I`m talking about the boot on the bottom of the master cylinder . Does the boot just slide down as I don`t want to force it out of there and break it if its not suppose to . Also which way would I need to turn the nut after I have put new pads on at the moment the pedal hardly moves and the brake dosn`t work .
Old 10-15-2008, 04:56 PM
picture does not work
Old 10-15-2008, 05:57 PM
Xuracing's Avatar
i don't think you want to play around with the piston, maybe the lever. You probably have air in there. Bleed it a few times. If it still doesn't work your MC is probably busted.
Old 10-15-2008, 07:07 PM
FLYOU's Avatar
I'm surrounded by black... with a gray to slightly less gray blob at the bottom.
Old 10-15-2008, 09:48 PM
StrikeAnywhere's Avatar
Why do people not want to use the rear brake? I use it all the time. Saves the front brake so it will last longer, if you only need a little braking before a corneryou can turn tighter with rear brake on than you can with front brake. The front is certainly the meat and potatos of braking.
I also feel like I am prematurely wearing out my clutch by downshifting at all stops to help slow the bike down. I'd much rather replace pads than replace clutch earlier than I should have to.
Quick Reply: Adjust rear brake ?
