520 conversion chain to long???
Old Aug 8, 2007 | 08:37 PM
slimbb4's Avatar
Default 520 conversion chain to long???
i got a 520 conversion kit... i installed the front and rear sprockets and then when i went to install the chain i realized that there are about6-7 extra links. the chain is way to long? what to do and why is it like that?
_zac
Old Aug 8, 2007 | 10:33 PM
woodyracing's Avatar
Default RE: 520 conversion chain to long???
your doing a 520 conversion, which means your changing both sprockets, right? the size of the sprockets (# of teeth) as well as the type of bike (length from axel to front sprocket) determine how long the chain will have to be so they sell chains in lenghts long enough for most applications (usually 120 links)
you have to cut it down to the length you need
Old Aug 9, 2007 | 01:46 PM
slimbb4's Avatar
i went down one in the front and up to in the rear. how do i determine where to cut it and how do i go about cutting it. thanks for your help
_zac
Old Aug 9, 2007 | 05:29 PM
speedra500's Avatar
I did it by just pulling the chain to the closest to the normal chain tension I could get where the proper link-ends line up and then cut it and put it together there
Old Aug 10, 2007 | 09:51 AM
dienasty13's Avatar
I just bought the 520 to but i was ganna cut it just didnt have any tools what do i need is that a pain in the rear to cut it?
Old Aug 10, 2007 | 09:53 AM
gixxereater's Avatar
Grind off the rivets on the link that you want to cut off and use a center punch/hammer to push the pins out........then reinstall new pins.
Old Aug 11, 2007 | 09:53 AM
slimbb4's Avatar
thanks guys for your help... i will probably do that today or tomorrow.
_zac
oldskool21
Mar 15, 2011 10:17 PM
adrenalnjunky
Sep 24, 2010 03:09 PM
fastspares
Mar 22, 2010 02:29 PM
mtxkidd2
Sep 30, 2007 12:18 AM
geraldscbr
Oct 4, 2006 06:18 PM
