2001 F4I ressurection
Old 05-04-2012, 05:08 PM
RudyGT's Avatar
and the fuel pump doesnt prime, now i gotta figure something out for a working pump. i have 12 volts across the pump lines.
Old 05-04-2012, 11:32 PM
mnguyen84's Avatar
https://cbrforum.com/forum/f4i-main-...l-pump-136231/
this guy's fuel pump didn't prime either. turned out to the be ecm. the thread could help give you some clues on what to check for.
Old 05-05-2012, 07:19 AM
RudyGT's Avatar
im actually getting voltage for it to turn on, it pulses but does no more.
if anything i would imagine its seized up. however the turn indicators not working
has me concerned.
as of right now without checking the bulbs the front left just stays on, and when i signal for a right turn it goes out.
for a left turn it goes off a second and comes back on. im hoping thats not controlled
via the ecu
Old 05-09-2012, 09:32 PM
RudyGT's Avatar
so i ordered a new fuel pump, but i need to work on the brake lines among a few other things.
like i said the bike has been sitting for 6 years or so, any suggestions? would just adding more fluid be a bad idea?
should i flush it out, disassemble, replace? its pretty straight forward to do a top end but brakes i know nothing about.
Old 05-10-2012, 01:30 PM
gotcbr's Avatar
Originally Posted by RudyGT
...the bike has been sitting for 6 years or so, any suggestions? would just adding more fluid be a bad idea?
A bike sitting that long should have every fluid flushed.
Old 05-19-2012, 07:19 PM
RudyGT's Avatar
so, here's the deal and i dunno what to do now. got the bike running and it ran great.
so i was letting it warm up to see if the radiator fan kicked on, and after a while it started idling rough.
at that point when i reved it it definitely was bogging down and not sounding right at all.
now there is smoke comming from the pipe and its not running 100%.
i pulled the plugs and they all looked the same. any thoughts?
edit: there could be a possibility of too much oil, i topped it off after it was running. and now as a cold engine
it looks borderline maybe a bit over when 90 degrees upright
also i tested the FPR i guess by taking the hose off and it blew fuel once the pump came on.
im so bummed out right now i dont know what to do
Old 05-20-2012, 10:02 AM
RudyGT's Avatar
and after draining a bit of oil, checking the spark and compression, i get
good looking spark, and no lower than 178 psi in 1, 2, 4 cylinders and cylinder 3 is about 135-140
also now there is gas leaking out of the exhaust with all that smoke.
Old 05-20-2012, 12:38 PM
RudyGT's Avatar
Anyone think it could be a stuck exhaust valve? It has been sitting for a long time, and as i stated low compression, perhaps the rings got stuck in the ring land due to carbon, getting hot enough? Its happened to me before on a diff bike. Would a stuck exhaust valve cause lower compression/unburnt fuel leaving the cylinder?
mnadeau
12-08-2012 09:26 PM
S2005
07-31-2012 10:26 PM
Quick Reply: 2001 F4I ressurection
