06 tail conversion exhaust question
Old Feb 16, 2008 | 10:13 PM
f4ez's Avatar
Default 06 tail conversion exhaust question
ok so ive searched this topic and really came up empty handed but i did the conversion on my bike 01-03 tail on my 06...anyways i cant get my exhaust to mount up without leaking like a bastard i loosened the bolts on the clamp slid it back just far enough to mount it on the peg and it leaks real bad and i was told that all i have to do is slide it back and i will be good and well im not so any hepl would be great
Old Feb 17, 2008 | 06:24 PM
oodayvidoo's Avatar
Default RE: 06 tail conversion exhaust question
do you have the stock exhaust or an after market one? if you have the stock one w/ the gasket undamaged you should be fine. i believe that all you have to do is basically check if it's screwed tight where it connects to the header.
if it's an after market one, check the diameter of the midpipe and measure it to where it connects to the header. it should fit... maybe it's just how you're mounting it is the problem.
Old Feb 17, 2008 | 08:12 PM
f4ez's Avatar
yea i still got the stock exhaust its hard to explain so i will just take some pics and post them up
Old Feb 17, 2008 | 08:59 PM
oodayvidoo's Avatar
oh i know now... you need an 01-03 stock exhaust. u can't use your 04-06 stocker cuz it is measured up to mount differently.
TooBroke0029
Aug 21, 2022 02:10 PM
goatxxmastr
May 30, 2021 08:24 PM
removebeforeflight
May 21, 2012 10:37 AM
Aukai
Mar 17, 2010 03:32 AM
ride_002000
Apr 3, 2007 01:54 AM
