'01-03 & '04-06 differences
![Question](https://cbrforum.com/forum/images/icons/icon5.gif)
Does any one know the difference between the 01-03 & 04-06 main wire harness? I have an 05 F4i that the harness is pretty chopped up - and I'm wanting to just pull it and start over. I just don't want to drop $200 bucks on a new one, but all the used ones I have been able to find are 01-03.
Can I use it?
Thanks for the info.
Barry
Can I use it?
Barry
i just checked, the only difference is the reg, rectifier and the ecu. they are much further forward-under the front seat instead of the rear.
if i remeber right, you have a split seat rear tho, im sure you could make it work easily
this is the 04+ diagram
http://www.bikebandit.com/houseofmot...m2054sch410441
the 03- diagram
http://www.bikebandit.com/houseofmot.../m2051sch95275
i hope that helps!
the 03- diagram
i hope that helps!
Hey thanks vangill... yeah, I had checked the differences on cheapcyclepart.som (same diagrams) and the only difference I could tell was the reg & rect locations. ![Icon Shrug](https://cbrforum.com/forum/images/smilies/icon_shrug.gif)
but they are different part #'s. Front harness is same part # and drawing in both diagrams. I just want to make sure the connections are the same, you know? that is what I'm worried about.
So you don't think the actual harnesses are different though? I don't know where they would be.
Thanks again for the info.
![Icon Bike](https://cbrforum.com/forum/images/smilies/icon_bike.gif)
![Icon Doh](https://cbrforum.com/forum/images/smilies/icon_doh.gif)
I traded for the bike so I would have something to work on and tinker with, been pretty fun so far. Wiring is just kinda kicking my butt - thinking it would be easier to replace than fix at this point.
