Wont start- ign related
Old Sep 29, 2011 | 07:25 AM
600$tunter's Avatar
Exclamation Wont start- ign related
Hi,
I recently rebuilt my bike as a streetfighter and in order to paint everything I tore everything apart besides the motor.
Prior to doing this, the bike ran fine on all 4 cylinders. The bike has been apart for about 1.5 years. It is finally back together,
and I have gotten it to run several times on 2 cylinders about 3 weeks ago. Ever since rebuild, I havent been able to get all 4.
It would start up fine, but infrared heat gun showed only 2 cylinders firing which were 2 and 3. I've been trying to test everything
and make sure all wires had good connection. Yesterday when I attempted to confirm that it was just a coil, I could only get spark out
of cyl. 3. So now it was only firing on 1 cylinder causing big backfires but the engine never ran. I kept checking, moving, switching
wires on the coils and now none of them fire. Eveything looked like it was connected and there is continuity. I made sure nothing was
left loose.
Does this sound like my ECU? I dont under stand why it would go from being fine @ 4 to 2 this year to 1 to 0 this month. I have it
jumped by a car battery so it has a steady 12v. Could it be ECU/CDI, R/R, Ignition pulse generator?
I've tested:
Both coils resistance per service manual => good
ECU harness per service manual (Power, coil power, ground) => good
I've switch coil wires around
Coil wires => Black w/White gives constant 12v power when kill switch is set to on. The yellow/blue gives off nothing even when cranking. A voltage spike is seen when i stop cranking. Is not shorted to ground.
What do you think is causing this?
Please help, I NEED to get this running ASAP. THANKS!!!
Old Sep 30, 2011 | 07:13 AM
600$tunter's Avatar
50 views and no thoughts? lol anyone??? ECU, wiring? Ign pulse generator?
Old Sep 30, 2011 | 01:10 PM
my94f2's Avatar
i hope someone answers cuz mines doin the exact same thing. i can get a big backfire while spraying start fluid but thats it
Old Jul 3, 2012 | 01:01 PM
600$tunter's Avatar
FYI an ecu off ebay and a new set of plugs fixed my problem. not sure which it was but im guessing it was the ecu because my problem was intermittant.
Old Jul 3, 2012 | 02:58 PM
JankCibberf2's Avatar
i was going to ask what your plugs looked like when you pulled them, they sounded like they might have been oil fouled after the rebuild
hawkgt
Aug 14, 2014 01:02 PM
C Jacob W
Jul 29, 2013 11:03 AM
Sand.Man
Oct 2, 2010 07:47 AM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
